Alpha 9 CD or Diva CD73?
Discussion in 'Arcam Owners' Forum' started by riverrun, Jul 4, 2004.
Tags:
  1. riverrun
    riverrun
    Jul 4, 2004
    37
    Which replacement for an alpha 7 CD would be better? (To accompany alpha 8 and 8p bi-amped)
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I would definitely look at the CD73 or you might get a good deal on a second hand CD82 now that they are discontinued.
  3. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    I would rather take one alpha9 than five CD73
  4. riverrun
    riverrun
    Jul 4, 2004
    37
    Plump, I've read your championship of the alpha 9 in other posts, but as crustyloafer suggests, isn't the CD82 not equal to it in specification, and being available new, with the advantage of a greater life expectancy than a used CD9 for approx the same money? (Also easier to find)
  5. Spligsey
    Spligsey
    Jan 16, 2003
    2,368
    UK
    +217
    I suspect that Plump prefers the DCS Ring DAC that the Alpha 9 has.
    Adz
  6. riverrun
    riverrun
    Jul 4, 2004
    37
    I would suppose the FMJ CD23 to be more Plump-friendly then? (And as hard to find as the Alpha 9)
  7. Spligsey
    Spligsey
    Jan 16, 2003
    2,368
    UK
    +217
    I would imagine that the CD23 would be to his liking - great player.
    I also think the CD33 is a class act too (non DCS ring DAC).
    Seen a few CD23's on Ebay, everynow & then one pops up on hififorsale.com
    Adz
  8. riverrun
    riverrun
    Jul 4, 2004
    37
    An alpha 7 can no longer be upgraded to an alpha 9, because of lack of parts, but for £200 it can be modified to CD82 specifications, according to Arcam (our main dealer in Ireland quotes 399 euro). An ex-dem CD82 would cost about £400, so that's not bad. However, for £300 you could probably get an alpha 9, and for a little bit more a CD23, which is what I finally did, based in part on some of the comments here. Now what do you do with a CD23?
  9. warrj
    warrj
    The Alpha 9 IMO, or as has already been suggested, a CD23. The RingDAC may be a bit long in the tooth but I'm not personally convinced that it's been bettered by anything in the Arcam price range - just my opinion you understand.
    Regards,
    Jules.
