Alpha 10/DAVE remote problems
Discussion in 'Arcam Owners' Forum' started by pinkmouse, Jun 27, 2004.
Tags:
  1. pinkmouse
    pinkmouse
    Hi Folks :)
    I wonder if anyone can help me with a little problem I have. My CR80 remote control seems to have completely lost all the Dave programming, one day it was there, the next it was gone...
    I tried the programming reset as instructed in the manual, but that does not seem to reset devices, just programmed codes. None of the listed codes, (for any amp device, I went through them all), restored the Dave programming. So, as it seems strange that the remote would just lose the code for one device , the only thing I can think of is that somehow another code was programmed over the top.
    So has anyone a clue as to how to do a total reset for this remote, or the code to put the Dave functionality back?
    Al/worn out from all the running around
  2. pinkmouse
    pinkmouse
    Bump
    No-one have any ideas? Oh well, time to take it apart then :)
  3. pinkmouse
    pinkmouse
    Problem solved, with great thanks to Andy Dutton and ARCAM's excellent customer service.
