ALPHA 10 +10 p
Discussion in 'Arcam Owners' Forum' started by andrew constant, Nov 8, 2003.
Tags:
  1. andrew constant
    andrew constant
    Apr 15, 2002
    215
    london
    +11
    I own a alpha 10 + 10p connected to a marantz cd 17 with VDH speaker cable connectet to my acuistic energy ae1 sigs,and the bass is so soft i have had 2 pass the signal through my av amp to boost the bass.has anyone else found this problem ?
  2. texasboy
    texasboy
    Sep 16, 2002
    390
    +15
    what i/c's are you using.
    I have found VDH to be a flat to be honest if you have i/c's to match your speaker cable.
    Chord or maybe Nordost would be a good alternative.
    I'm sure a dealer somewhere would have dem lengths somewhere.
    I used to have a 10/10P/9CD when they first came out several years ago and used Nordost Blue Heaven throughout (inc speaker cable) and it was anything but soft, very dynamic sounding with being too hard on your ears over time.
    Hope this helps.
  3. pinkmouse
    pinkmouse
    The AEs aren't the best speakers for bottom end, I used to run a pair as rears, and was never that happy with them. You could try stuffing the ports with foam or similar, that might tighten up the response of that little bass driver.
  4. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I added 3 Alpha amps (10 Int amp section, 10P/3, 9P) to my AVR300 and it improved the bass response of my system. It's now tighter, faster, and more detailed. Offhand, I would say your problem lies elsewhere.
    Dean
