allshare problem...help!!
Discussion in 'Mobile Phones Forum' started by Brian1869, Jan 9, 2012.
Tags:
  1. Brian1869
    Brian1869
    Sep 20, 2006
    72
    When i am trying to stream videos from my galaxy note to my tv there is no sound. The video plays fine. I have checked the settings on my phone & tv but cant find anything to sort it. Anybody else have this problem?
  2. andersoncarry
    andersoncarry
    Dec 23, 2011
    5
    hi, i think you have going a nearest service center because i am aslo used note and connect to my tv but. i am not face that types of problems and i heard sound clearly so i hope you get a proffesional help from them good luck!!!
  3. bobfoc
    bobfoc
    Nov 17, 2005
    1,965
    Bishops Stortford
    +134
    Could be in relation to the codecs and containers being used.
    I've found that DLNA is very fussy with some of my files playing perfectly on the phone itself (Galaxy Note), but refusing to play via AllShare.
    Think the best bet would be to source yourself the HDMI cable adapter for your phone. This will allow you to play any compatible file directly rather than relying on AllShare/DLNA.
