Alloys - Any tips ?
Steve N
Anyone got any tips on how to keep your alloys looking good.
It doesn't seem to matter what I use to clean them, I eventually end up with areas of ground in brake dust and grime that just can't be shifted.
I'm changing my car in a few weeks time and just wondered if there is anything I can apply, while they are still new, that will keep them looking good. I thought that maybe there may be some sort of coating or something.
I would also be interested on what other people find best for cleaning them.
Beobloke
Halfrauds Alloy Wheel cleaner is very good, although if my experience is anything to go by, you do run the risk of finding a spray bottle of it that dribbles more of it down your hand than onto the wheel.
Layne RIP
There are a fair few waxes now that are designed to be used on alloys.
Personally i use alot of Meguires stuff... and on my wheels after washing them i tend to give them a quick wipe round with the speed detailer (not the best thing to use) but it does help to keep the brake dust at bay a little longer!!
I am quite hot on keeping my car clean though so the wheels never really get that dirty!! ;)
Hairy
Best thing is to just clean them regularly,at the very least once a week.:smashin:
eviljohn2
Get them thoroughly clean properly as part of cleaning your car normally.
Polish your car a few times with Autoglym Super Resin Polish.
Finally carefully put 2 layers of Autoglym Extra Gloss Polish on top. If you follow the directions carefully it'll remain nice and easy to keep your wheels clean, as long as you polish again when necessary. Londondecca is the forum member who knows loads about this. :)
Londondecca
The trick is to get the wheels spotless before applying any sealants. Wash the wheels and then spray the wheel cleaner, agitate the solution with a soft brush and rinse. It is far better to use a mild cleaner twice than a harsh cleaner once. Rinse, dry and apply something like the Autoglym SRP & EGP. You do not need to buff the SRP before applying EXP. Leave it to cure for about an hour, buff, your wheels will look great and be very easy to clean when the car is changed
Clean the tyres at the same time and scrub with a upholstery brush, dry and then apply your favourite tyre dressing - leave it on for at least 15 minutes and then buff off
rhino2k
the absoloute best way to clean alloys properly, no matter what the cleaner, is to..............
remove them from the car, you can do a far far superior job, and clean the inside of the rim properly which needs doing fairly regularly (say every 2-3 months) to keep them nice :)
Steve N
Thanks everyone :thumbsup: (why have they removes the thanks button ?)
Lots of good ideas there for me to try.
Londondecca
100% agree, this is also a good time to clean the wheel arches but dont use a dressing on the plastic
rhino2k
to be fair though when you have spent half a day cleaning the car taking the wheels off is no so appealing :D
i found it better to keep a few hours aside on a seperate day to do them, before cleaning the car is better as you are more motivated to clean it and a quick blast with the hose brings them up good again :D
Uridium
wonder wheels is the stuff you want. cleans mine in seconds.
originally designed for use on bikes (chain lube is a nasty sticky mix of oil and glue:( )
Kebabhead
Joe90sDad said:
But read the warning label on the back of Wonder Wheels - its not advised for certain finishes.
It's certain type of alloy wheels such as classic Jaquar wire spoke wheels that it's not recommended to use.
Have no trouble with it on my alloys - good results all the time
Even better if your a Costco member as you can get 5 litres for around £9 including VAT
Steve.J.Davies
Coincidence.
Going to Costco later this week and just put new alloys on wife's car.
Anyone shed any light on the 'certain types'. How do do/will I know what 'types' and if the new wheels are one of them.
rhino2k
Steve.J.Davies said:
Coincidence.
if they are laquered alloys they will be fine mate, virtually all alloys are now laquered (and usually painted) finish :thumbsup:
i believe you need to be careful on some bare alloys :)
[email protected]
My car used to have a terrible problem of brake-dust build up in what seemed like no time at all between washes. The answer?: I bought some green-stuff replacement brake pads. Now not only does the car brake better, but the alloys stay shinier for longer:smashin: :clap:
Steve.J.Davies
Not trying to be thick here but...
how do you tell the difference ? between laquered and non laquered etc.
have attached pic in case anyone knows...
rhino2k
they would be fine with the wonder wheels mate :thumbsup:
if you look at some older cars with aloys you can see when they are "bare" quite easily :)
Steve.J.Davies
This is an M reg car. the wheels are manufacturer replacements. though I believe there was a slight spec change in the intervening years - don't know when.
that fall into 'older cars' ??
sorry - but still no yardstick I can use to tell what is a suitable case for treatment and what isn't..
rhino2k
they should have a similar finish to your paintwork on the car mate :thumbsup:
care alloy is generally quite rough and pitted looking, unless it is highly polished, but the it would be laquered anyway to preserve the finish :thumbsup:
Steve.J.Davies
paint work is dark green metallic so they don't -- just joking, though that is colour of paint... :)
don't look anything like paintwork to me.
I wonder of there is anyway to find out from part number.
may have to go to dealers and ask - bet they have some whizzo super stuff to sell me !!
Not my car, SWMBOs.
SeanT
Get some Supagard alloy wheel cleaner and sealer off ebay for about a fiver - it works great.
Londondecca
Here is Paul Dalton in action http://www.youtube.com/watch?v=PkmZveqyU5E&NR
The process is straightforward aside from the costly products used. Equivalent products are available in the UK ie clay, gel wheel cleaner etc. Of course the skill is in using the products in the right way but it is possible to get a Concours finish for a lot less money without the need for esoteric products.
V
VXRman
I swear by Meguiars, won't use anything else!
watch for acidic wheel cleaners, they will do damage over time.
I take mine off once a month and give them a damn good scrubbing, but other than that Meguiars Hotwheels and then a wax when i clean the car (once a week weather permitting!)
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
Latest News
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
