all these leads and no idea.....
Discussion in 'LCD & LED LCD TVs Forum' started by jodie114, Feb 8, 2005.
Tags:
  1. jodie114
    jodie114
    hiya, looking for some help....
    just got some new equipment, and now all i have to do is work out how to connect it!
    i have the philips 9986 lcd tv, a new toshiba sx32 hdd dvd recorder, and a sony sky digital box that is about 4 years old. i want to connect them the best way, using the progressive scan fature on the dvd and tv, but can't get this to work.... any tips?
    Also, i have a samsung home cinema 5.1 system i would like to use as an amp now i have a better dvd player.. how would i add this to the system? please help all this lovely technology and i can't play!
    jodie
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    What model is the amp ?
  3. jodie114
    jodie114
    its a samsung ht-db120
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Right....
    DVD player->TV via Component to VGA to DVI adapter thing you get. This will give you Prog Scan.
    DVD player->Samsung 5.1 via optical if the DVD player has optical out.
    SKY->TV via Scart for video.
    SKY->Samsung 5.1 via phono for audio. This isn't great because you don't get 5.1 surround from Sky with this option. There might be an Optical switch box out there though.
    I've only had a look at the connections from the websites so you'll have to check. The PRog Scan will work though.
    Richie.
  5. jodie114
    jodie114
    thanks rich, sounds good. now to make things more difficult for you....
    can i add a magic eye to get sky upstairs.... where would i put that coax cable?
    jodie
    btw: i know i sound SOOO daft, but what is an optical switch box?
  6. garsmi
    garsmi
    Hi Jodie, the optical switch box will allow you to connect the optical cable from the DVD and Sky into the Samsung surround so you can enjoy the 5.1 surround sound from both. You just switch to either DVD or Sky depending on what your viewing.
    I will be looking into this too in the future... If I find one I will post the website!
    Good luck with the setup.
    Forgot your first question... the magic eye coax cable will plug into the RF output on your Sky box. Might also want to think about a DigiSender which will send your Sky to any room without cables. Check them out at Argos for about £80. More dosh but can be put into any room plus you can add new rooms/tv's anytime.
  7. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Thanks Garsmi, I haven't a clue about the Magic Eye since I haven't got Sky ! I just know the best way to connect it :)
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Magic eye needs to use RF2 output on Sky box normal coax from box to second TV, and connect eye at second tV end
  9. sbheaven
    sbheaven
    Jan 20, 2005
    12
    Agree with RichJ about setup - but to make progressive work you need to press the progressive button on the Tosh - and suddenly your picture will appear
