all the people with tosh dlp what dvd player
kourosh
:hiya: ive just bought this tv but having trouble deciding what dvd player to go for :confused: i wanted the samsung 945 as it had the hdmi but cant get hold of it till mid march as every where is sold out :( there is a few players that im considering and i wanted your views if you have them with your sets first 1 the sony 999es it retails for about £1000 but as i work for sony i can get it for £400 and it dont have hdmi the second is the denon 2910 and the third the pioneer dv668 i had a hard time deciding which tv to go for now its the blimin player so :lease: help :beer: :beer:
whiteswan
Go for a decent HTPC............
You can play hi def stuff then as well............
As a tip - the Aldi pc's are due in the next month - always very fast and very hi specced and should suit your needs fine.
I have last years - it has rgb scart - svideo - composite - vga and hdmi out !!
Excellent machine.
Dave, Oldham.
kourosh
ive just aspent £1100 on a pc back in october dave the thing is i really didnt want to spend to much cause in nov time the high def dvd players come out so i would be getting one of them and im sure they wont be cheap the pc is quite good its one of them entertainment pc watch tv pause live tv etc but it dosent have dvi or hdmi out
n00b
dave do you upscale sky through your pc? i know you can get input cards but im wondering if its worth it when the £100 sammy dvd player will also upscale. is it possible to use the pc while its upscaling?
whiteswan
No I dont upscale...........
But for £600 - £700 which is what the new Aldi pc will cost - i think its a no brainer!
Dave, Oldham UK.
kourosh
does the sam745 do upscaling then? and also will the quality be the same as the sam945 thats got hdmi thanks noob
kourosh
thanks for the replys ive just read the reviews and it seems good so the panasonic it is if i could have got the the denon a bit cheaper then i would have gone for that 1 but i didnt want to spend £470 now then loads more on a hidef dvd in 9 months time thanks again
KableMan
TonyA
Although I still haven't got my Tosh yet (have to wait for some building work and decorating to be completed first!), I've just bought the Panasonic DVD-S97 in advance of me getting it.
I've hooked it up to my ancient old JVC CRT via RGB scart, and the picture is absolutely stonking!
I cant wait to see what this baby will do over HDMI to the Tosh!
Got a good deal on it too - webelecticals.co.uk - got a multi-region version for £219.99 including VAT & Delivery!
Only got it yesterday, and still playing with it and finding my way around, however its managed to play a disk what I thought was a corrupt disk and which wouldn't play on two Philips systems, and my laptop's DVD players - without a single problem! (Good little crash test for it!) :)
One thing I'm trying to get used to though, is remembering to use the "Position Memory" before powering the box down, or swapping disks in and out of the player.
My old Philips would do that automatically - does anyone know of a setting that can automate this on the S97?
The only downside I can see to the S97 is the manual which in my opinion is bloody awful!
kourosh
i sure will cableman the tv is coming next wed so as soon as i get the player(not decided where to order from)i will let u know what the picture is like a bit p***d of cause i was in london yesterday trying to look for the samsung which know 1 had and i never knew panasonic did a hdmi player cause im sure that would have been in stock just hope i dont have to wait to long :thumbsup:
