All Sony system - problems when watching Blu-ray
Discussion in 'Home Cinema Buying & Building' started by hockenpj, Jan 30, 2009.
  1. hockenpj
    hockenpj
    Apr 4, 2008
    2
    I have the following kit:
    Sony STR-DA2400ES
    Sony BDP-S550
    Sony KDL-40Z4500
    When I watch Blu-ray discs the image flickers and snow appears on the screen and the 1080/24p indicator appears on the screen, it seems to happen at similar points during particular film.
    I am hopeful that the amp is in good working order as it has already been replaced by the vendor.
    Any help would be appreciated, let me know if you need any further details to aid the diagnostics.
  2. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,506
    Do you have any other hdmi cables to try?
  3. hockenpj
    hockenpj
    Apr 4, 2008
    2
    I have tried three different types of HDMI cable.
    All of which are very short
  4. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    Sounds remarkably like the issues I had Sunday with my Sony kit.
    I'd updated the firmware as I had a disk which would not play correctly. i tried a few dvd's as well and got similar issues.
    The remedy was to replace the short hdmi cable, the problems went away completely.
    I was almost at the point of packing the Bluray player up to take back.
  5. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,506
    What happens if you connect directly i.e. not via the amp?
  6. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    Went to watch a bluray last night and I got the issue back again. Connected the bluray player to the tv direct and no issues. It does appear to happen to me at the same points in the movie - note I have the same amp which is worrying.
    Will try to find the cause after work tonight.
    Update
    I think I've managed to resolve my problem and hope it may help sort yours.
    I reset the BD and Amp back to factory settings. Then setup each device one at a time with the others switched off. I noticed that having renamed the inputs they are now appearing correctly in the display of the amp.
    For the sound I followed other threads about setting the audio to 'amp only' and the BD to direct.
    Cross-fingers it seems to be OK now, hope it's still OK next time I use it.
