all sharp lcd owners
Discussion in 'LCD & LED LCD TVs Forum' started by andya, Dec 7, 2004.
Tags:
  1. andya
    andya
    Oct 25, 2002
    2,432
    48
    manchester
    +35
    say you have your comp connected to the dvi socket ,how will you connect a hdmi dvd player or skybox e.c.t. would you use some sort of dvi switcher box and does it not bother you that it hasn't got both connections
  2. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    I think you can get a DVI switch of some kind, to allow more connections.
    I don't care that it only has 1 DVI. 95% of the things I watch on it are from a PC anyway.
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    In the future, AV receivers will do HDMI switching. At the moment DVI and HDMI swictches are available, but they are very expensive. One of the main features of HDMI is the ability either 'daisy chain' digital devices or switch them. HDMI will also handle control of each device too. When HDMI is common place, you will just plug each HDMI device into your AV controller with a single cable rather like you might do now with SCART or multiple component/RGB/audio connections.
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    And until AV receivers drop dramatically in price (Cheapest is £700 I think from Pioneer and it's out yet), is there a way of getting a graphics card with HDMI as an input and routed back out ? You might be able to daisy chain it that way.
    I am in computers but I don't know whether you can actually do this !
    Richie.
  5. Ultim8Fury
    Ultim8Fury
    never seen a graphics card with HDMI. If it exists you can bet its seriously expensive pro-sumer grade gear.
  6. 1ofaKind
    1ofaKind
    Dec 16, 2002
    233
    Midlands
    +4
    I think av amps with hdmi or dvi are coming but they are top end (new Denon,Onkyo etc).
    PC HDMI - well I thought HDMI was designed to carry audio & video with copy protection etc which doesn't seem to fit with a PC style interface. DVI is where PC's will mostly like stay I would have thought. Though of course I believe you can convert DVI --> HDMI and vice versa.
  7. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    If you have spent the money on (and effort to find) a HDMI / HDCP DVI compliant panel display and have multiple HDMI /DVI sources then are you really likely to be scrimping to that extent on the AV amp that you're routing it all through?
    I can't remember the company name but I was looking at some HDCP compliant 3-to-1 DVI+optical SP/DIF+electrical SP/DIF switchboxes the other day that weren't *TOO* scarily priced - about $500.
    Phil
  8. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Sorry, I meant DVI. Can graphics cards be used as switches or by the time you've bought 2 cards you can buy a dedicated switcher for the same price ?
    Richie.
  9. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Unfortunately, no, DVI graphics cards can't be used as switches and - even more unfortunately - no, by the time you've bought two DVI graphics cards you are nowhere close to the cost of a dedicated DVI switcher.
    Phil
