IceStation
Hi all,
Im looking for a new BR player to replace an old pioneer unit. I understand that all BR players should play BR's equally well but I'm also looking for it to do the following:
Upscale DVD's to 1080p well
Be quiet in operation
Quick to load disks
I'm not that worried about Smart apps, if they're there then great but not a deal breaker. I have just ordered a Sony HW40ES PJ and am therefore not concerned about 4k in the near future either. The Oppo 103 is a little over budget and was considering the Panasonic BDT700. Can anyone recommend others that fit the requirements? Was also looking at the Sony and Samsung players but the Panasonic seems to get better reviews for upscaling DVD's.
Many thanks for any suggestions.
Quick to load disks
