Teppic
Established Member
Hi, I know there have been threads of a similar nature in the past having just spent over an hour reading through search results, but they're all quite old and this problem is constantly drawing a blank with Sky, who just insist there's nothing wrong and constantly contradict their own official documentation and press statements. There's a thread on another well known forum where several people are currently being given the complete run-around by Sky, and I thought I'd check in here to try and gauge how wide-spread this issue is, or to see if anyone has some advice to give?
The problem: All channels which can not be watched without a Sky subscription are copy protected, regardless of if copied 'live' or from recordings to the internal hard drive. Any calls to Sky result in them insisting that all the programmes you try recording just happen to be "one of the programmes which is protected", or in some people's cases being told it must be the fault of their recording equipment. If you persist, Sky will then send signals to the box which they insist will fix the problem (contradicting all the claims it wasn't a problem). These signals never seem to work for anyone. Their next step is to send a new viewing card (as detailed as a fix for a similar issue in this thread: "Can`t record from sky+ to dvd recorder". However, the result of the new card is to make the problem worse - what was an intermittent problem with the old card (a copy protect signal being picked up roughly once or twice every hour or so) suddenly becomes a complete copy protection lockdown of all channels with the exception of those which are available without a viewing card. Other people have had their box swapped - in every case I know of never for a Pace unit which is the only make of box not to have lots of reports of this problem - which has never seemed to help matters at all. Where engineers have been sent out to investigate, it only ever seems to result in a confused engineer unable to help.
Copying to a DVD recorder causes the recorder to stop with an alert that a copy protection signal has been detected. Copying to a VCR results in the usual Macrovision effects ruining the recording.
Last October Sky admitted to sending out a faulty software update which caused this fault on certain models of Sky+ boxes (link: "Sky+ glitch sparks fears for programme backups"), but Sky claimed to have fixed this last year and mentioning it to anyone you can get on the phone results in nothing but denials that the problem could be related to the system software and them continuing to force you down the same path as everyone else experiencing this issue. Not a single person I'm aware of who has developed this problem since Sky admitted to having done a software rollback in the link provided has managed to get Sky to fix the fault. Indeed, I've seen examples of Sky willing to lose a customer rather than continue to try and resolve the issue.
I've contacted Sky about this via the [email protected] address after the last call I made to them resulted in me being put through a viewing card replacement which the person I spoke to even eventually openly admitted wouldn't solve the problem, and then discovering that the new card made the fault so much worse (just as I had tried to explain would likely be the result from what other people had experienced). It's now been almost two weeks and I've not received anything in reply, despite people with other problems regularly reporting increased help when using that address.
My Sky+ box details:
Manufacturer: Amstrad
Model Number: A2P0524
Version Number: 4F2109
Operating System Version: 1.31B03
EPG Software Version: 5.02.f
This box was a replacement from Sky when my old Pace box lost all Sky+ features after the last software update they sent out (costing me another £65 of course). Right now I'm wishing I'd tried replacing the hard drive in my old box rather than calling Sky. Especially as the Amstrad has a couple of other faults (switching itself to letterbox mode regardless of being set to 16:9 if you try to use the 'Copy' feature, and the box randomly freezing on playback from its internal hard drive and in one case it also doing so during live viewing).
Recording to VHS tapes via the multiroom standard box we have works perfectly. Pointing this out is the only way I ever get Sky to accept that their regular channels shouldn't be copy protected and begin to take me seriously, but every call ends with yet another dead end of them insisting "the problem you have is not a fault!". Overall, Sky seem content to allow any customer with the problem to either leave due to it being 'unfixable', or have their customers buy equipment to strip the copy protection from their whole system (which you would think they would be falling over themselves to prevent).
