all in one system with optical
Discussion in 'Home Cinema Buying & Building' started by pea69, Feb 3, 2009.
  1. pea69
    pea69
    hi i'm looking for all in one system with optical so i can use my xbox 360 and sky hd by using an optical splitter switch-
    does the all in one system have to have an optical input or output?
    thanks
  2. tom 2000
    tom 2000
    Mar 21, 2008
    3,988
    Craigavon, Northern Ireland
    +407
    You are looking to have an all in one with at least one optical input. I cant see why it would have optical output as the systems are designed to deal with the signals they receive, not to pass them on.
  3. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    There's no need for an optical switch - just get a system with two or more optical inputs.
    Pretty much every all in one amp & speakers system will have optical input. Have you any other criteria to narrow it down? Budget, future use of blu ray, other equipment you want to connect to it, type of speakers, etc?
  4. teenwolf69
    teenwolf69
    Nov 25, 2008
    37
    11
    Bolton (roaming freely)
    try an all in one sound bar, the denon dht-FS3 is a great system and comes with its own subwoofer.:thumbsup:
    Great sound bar, can be found at an affordable price, looks stylish and compact and has quiet alot of connections, 2 x optical, 2 x audio, 1 x coaxial.:clap:
    check my signature if you wan't to see what it looks like:smashin:
