All-in-one system to Samsung 55" 3D LED (8series)
Discussion in 'Home Cinema Buying & Building' started by pera82, Nov 26, 2010.
  1. pera82
    pera82
    Nov 26, 2010
    Hi!
    I have a Samsung 55" 3D LED 8 series tv and I'm buying an all in one system to go with it.
    I have singled out the Panasonic SC-BFT800 as it fulfills my needs (3d compatible, not many speakers, iPod docking..) My only concern is I'm unsure how this "speaks" with a Samsung TV.
    Is it possible to controll the sound on the Panasonic using the volume on the tv when i watch tv? Or do I always have to use both remotes?
    Does anyone have other suggestions for a solution?
  2. jumborat
    jumborat
    Jan 26, 2008
    465
    +77
    The two devices will connect together fine. Use an optical cable to connect them together then enable Anynet on your TV and Viera Link on your SC-BFT800. You'll be able to switch on the Panasonic via the Anynet menu on your TV, the TV speakers should auto mute and the TV remote will control the Panasonic's volume.
