All in one system for Panasonic TH42px70
Discussion in 'Home Cinema Buying & Building' started by Bobred, Jan 23, 2008.
  1. Bobred
    Bobred
    Nov 15, 2007
    30
    I have the above tv being delivered next week and want a suround sound system to go with it.
    I had my mind set on the Panasonic SC-PT450EB dvd surround system but after reading comments on hear I believe that this system will not be compatible with a SKY+ box, as I often have Sky tv through my surround system.
    Can anyone recommend a suround sound for a similar price (£150)
  2. HenryGM
    HenryGM
    Jan 15, 2007
    38
    The SC-PT350W has an optical input for Sky+. It has wireless rear speakers which was my main reason for getting it at the time. It works very well with the PX70 through the Viera link. When you turn the television on, it automatically turns on the home cinema and mutes TV speakers. (Can be disabled if you don't want that.) Gives very good Dolby 5.1 from Sky+ films as well as from DVDs. It's dearer than your stated price but I don't know what cheapest available is. Mine came with a discount as part of a special offer with the TV.
  3. Bobred
    Bobred
    Nov 15, 2007
    30
    Thanks Henry. I will have a look at this system.
  4. Bobred
    Bobred
    Nov 15, 2007
    30
    Henry, what cables have you linking up your components?
    Thanks Bob
  5. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    The next model up SC-PT550EB
    has what you need
  6. HenryGM
    HenryGM
    Jan 15, 2007
    38
    As far as the Home Cinema system goes - output from there to TV using HDMI. Input from SKY+ to it using optical and phonos from TV for other sound.
    All other devices got to TV via scarts and/or the other HDMI input and sound then goes from TV to 350 via the phonos.
    You set the TV to output sound via "Home Cinema".
    You have to switch the home cinema sound between Digital In for SKY for 5.1and Aux for other TV sound as the sound from the TV phonos isn't genuine surround although the ProLogic decoder does quite well.
    I think there's a big advantage in keeping to the same make for Home Cinema and TV. I've got Panasonic DVD recorder and VCR as well and switching seems to work very well. It would be nice to have more than 1 optical input but as you found some devices don't have any. But home recorded DVDs don't record the Dolby 5.1 sound anyway.
  7. syko
    syko
    Mar 22, 2007
    59
    hi i've got the same tv and also have a ps3 would the SC-PT450EB work for me?
    also is there a version without a dvd player?
  8. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
  9. syko
    syko
    Mar 22, 2007
    59
    the sony looks a lot nicer has it got better sound quality and would it be as simple to use as the panasonic as it use's the viera link thing to switch automatically?
    thanks
  10. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    Yes, imo the sony has a nicer sound, the viera links not important, after all its only a couple of extra remote clicks without the link
  11. syko
    syko
    Mar 22, 2007
    59
    thanks i'll look into the sony ones is the HT-SF1100 any good will it dhook up tv my tv and give me 5.1 on my ps3?
