All-in-one recommendatons
Discussion in 'Home Cinema Buying & Building' started by Staticbob, Jan 13, 2004.
  1. Staticbob
    Staticbob
    Jan 13, 2004
    3
    Have read through most posts, but still not found myself a definative answer !
    I have upto £400 to spend. My only real requirement is smallish wall mounted speakers, similar to the Sony DAVS500 . . . and inputs to connect audio from my PC so I can bang out MP3s.
    Do I go all-in-one or separates, and which systems.
    Bob
  2. Bigmonty69
    Bigmonty69
    Jan 7, 2004
    792
    +70
    If you can stump up another £90ish pound I'd got for the Jamo Dvr 50 305 speakers as it has both Pal and Ntsc progressive output (assuming you can make use of it).
    If not the Panny Scht900 (or something like that) was very well reviewed but has quite large but stylish speakers.
  3. DDDavo
    DDDavo
    I use my davs 550 mainly for sound. Superb output quality. I have my TV, VCR, Keyboard and PC hooked up to it all outputing stereo outputs. The S550 does a lovely job of using PL2 and creating simulated surround sound.
    It can be bought for an absolute bargain at £250 ish at www.richersounds.co.uk i think. That'll save you a bit
