All in one or separates?
Discussion in 'AV Receivers & Amplifiers' started by shez316, Feb 28, 2002.
  1. shez316
    shez316
    Feb 25, 2002
    117
    +3
    I can either get a Sony DAV S500
    or
    a Sony HTK215 + Pioneer DV444
    Which is better for sound/picture?
    My budget is £500 if you can think of better alternatives.
    Thanks Guyz!
  2. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    I think most (90%) people here will advise you to go for seperates...
  3. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,013
    Inbetween Upgrades !
    +7,311
    The seperates route is definately the road to take.
    If this is your first step into A / V and DVD, then it wont be your last ! Going the seperates route will leave more scope later on for upgrading. If you buy a complete package then that's what you'll be selling if you want to upgrade anything later. Seperates will also more certainly bring you better results.
    You probably will get bitten by the bug ! So go the seperates route and have fun.
    Kev
  4. Doubledoom
    Doubledoom
    seperates virtually everytime.
    There are too many features missing from the Sony DAV range to make it a serious option - for the money you need to spend on it.
  5. shez316
    shez316
    Feb 25, 2002
    117
    +3
    So do you guys think that the Sony HTK215 + Pioneer DV444 combo is a good choice?
  6. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    +6
    Before going any further....
    Take ahold of your credit card and say 10 times in a loud clear voice.....
    "I will not spend more than my budget...."
  7. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    For quality, value, performance and upgradeabliity, seperates.
  8. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    May I recommend the Yamaha HTIB40 again (£380-400). I still think its great and better than the Sony. Just add any DVD player. This may push you a little over your budget but well worth it.
  9. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,627
    United Kingdom
    +2,233
    Whilst some all in ones are pretty good, generally you´ll get better performance from seperates.
    Also its possible to upgrade which you cant with all in ones.
    I´d go for seperates every time.
