All in one jobby for very old tv
Discussion in 'Home Cinema Control & Remote Controls' started by The Robman, Jul 17, 2003.
  1. The Robman
    The Robman
    As it's a Sony I think a cheap universal will do the trick. Sony has been using the same TV code for quite a while.
    I would recommend a One For All if you can find a cheap enough model (I forget what models are available in the UK), but any universal that claims it can work a Sony TV will probably do.
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    My grandmother has managed to lose/break/cook or something the remote control for her tv. Ideally all she needs is something to do channel up and down BUT the tv is possibly 12 or more years old (its a sony). Will one of the cheapy all-in-one remotes do the trick?
    thanks!
    Ad
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    errrrrrrmmmm....... how come my post is second!? I was the thread starter!!!!
    All for one is what i meant, all in one..... it sounds similar!
    thank you!
    Ad
  4. The Robman
    The Robman
    That is weird isn't it, it must have something to do with me posting from Chicago and you being in Belfast.
