All For One codes wanted.
Discussion in 'Home Cinema Control & Remote Controls' started by Garrett, Jan 27, 2002.
  1. Garrett
    Garrett
    Apr 21, 2001
    43,632
    2
    167
    The best thief you'll never see.
    +8,389
    Can an one on tell me the codes for a All in One programmable remote (URC-2502) to give the functions of a Panasonic, Search + and - (pause advance and back). I have been on their site but cannot find them.
    :cool: Ruby quartz shades.
  2. Noman
    Noman
    Phone or mail them. They have always been very helpful to me.
  3. Garrett
    Garrett
    Apr 21, 2001
    43,632
    2
    167
    +8,389
    Please can you let me have their phone number. I have been ringing them on the number that came with my remote, and got some codes for the TV this was 5 years ago, now when I ring them it sound as though the have changed there number (may be a new area code of business code).
    Thanks in advance.
  4. Tricky
    Tricky
    Ok i have this number for them
    08081000306
    e-mail: [email protected]
    fax:+31 53 432 9816
  5. Garrett
    Garrett
    Apr 21, 2001
    43,632
    2
    167
    +8,389
    Thanks all, I will ring them tomorrow.
    :cool: Ruby quarts shades
  6. Garrett
    Garrett
    Apr 21, 2001
    43,632
    2
    167
    +8,389
    Hi Norman and Tricky
    I tried ringing them today and was given another number and told it was £1 a minute, I also e-mailed them and got a reply that went something like this "If you cannot use the Internet, e-mail us filling in the following" If I can’t use the Internet how did, and how would I contact them!
    So if you have the following codes could you post them:
    Panasonic Digital Sat TU-DSB30, I have tried codes 328 and 455 and they do not work
    Sony mini disc player JA20 ES, I have tried codes 000, 397, and 490 and they do not work
    Panasonic search buttons for the NV-F70B video recorder. (this is a slow frame advance and back in pause mode).
  7. Arthur.S
    Arthur.S
    Shame they've gone the quid a minute route now. I used to find them really helpful. I think you may find that the codes aren't in your remote. In which case you'll need to get them to transmit them over the phone to your remote. Works like a modem, they transmit, you hold the remote to the ear piece. The last time I did this, I made an appointment by e-mail for them to ring me!
  8. Garrett
    Garrett
    Apr 21, 2001
    43,632
    2
    167
    +8,389
    Why can’t they just put the codes on their web site.
  9. Arthur.S
    Arthur.S
    If you're talking about a list of codes, then yes they can do that. (If they haven't done already) But if the code itself isn't in your remote, then just keying in the code number won't work. You have to get your remote upgraded via the modem/phone line that I mentioned earlier. I did this with my Sky digital box, & my American DVD player. I've since moved on to a Pronto, so the One For All is redundant now.
