All change....M&K K-4 positioning
Discussion in 'Home Cinema Speakers' started by Dak, Nov 27, 2003.
  1. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    I am moving the room about and am not sure where to put the K4 tripole rears. The settee is 12 inches off the back wall and I planned to put the K4's on the wall behind at either side.
    I have seen a number of installs that have them on the side walls though.
    What are the pro's and cons? Will I notice a difference?
    For info I have a Denon 3803 on the way but don't think that I will go any higher than 5.1 at the moment - and for a good while.
    Dak
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    If it is any help I have my K4's on the side walls a couple of feet out from the rear wall firing across the seating position.
