ALL 963saOWNERS-PLEASE HELP
Discussion in 'Blu-ray & DVD Players & Recorders' started by ebury, Jan 21, 2003.
  1. ebury
    ebury
    Nov 5, 2002
    1,250
    41
    london
    +12
    hi all,just noticed some green colour bands to the left of my plasma,whilst watching a r1 dvd on the 963sa.checked a few more titles and can see the (faint)green lines on nearly every film.also checked pal films but could hardly see any lines at all.could this be a problem with the macrovision system?if so,is there anything that can be done to get rid of the macrovision?Im using a toshiba wp16(4 series panny)conected directly to the philips with supra av3 rca leads.please help!!!!!!!!:( :confused: :confused: :confused: :confused:
  2. ebury
    ebury
    Nov 5, 2002
    1,250
    41
    london
    +12
    no clues anyone???I've been looking over at avsforums and have found a couple of people with similar problems.they say it does happen with some other philips models including the earlier 962model!still dont know what to do?do i contact philips directly or wait to see if anyone else has the problem in the uk first? sorry about the long posts!!!:mad:
  3. jmack
    jmack
    i have the toshiba 42 plasma aswell and a philips 962sa from hivizone pal/ntsc progressive and have know problems
    is there a seperate component outputs on the 963 interlased/progressive maybe try the other?
    sorry cant be any help
  4. ebury
    ebury
    Nov 5, 2002
    1,250
    41
    london
    +12
    j-mack, theres only one set of comp' outputs.thanks anyway:D
  5. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    ebury, what he's asking is to try the player in interlaced mode, non-progressive scan..
    do the green lines show then?
    maybe a tosh fault rather than the player?
  6. ebury
    ebury
    Nov 5, 2002
    1,250
    41
    london
    +12
    ive tried switching between interlaced/prog,but still get the lines.in prog they are slightly thicker though!Can't be a fault with the tosh because its fine with other players including the now returned limit9500se,which did not show any lines at all!!
