All 4 on You View - Sony TVs
vinn
Hi viewing catch up TV on Sony A80J through you view. No issues with BBC iPlayer or ITV hub but a problem with All 4 - audio description is on by default and there doesn’t appear to be anyway to turn this off. I’ve tried using the audio button on the remote and also looked at accessibility in the settings but no luck. Anyone have any ideas??
gjd000
It's an All4 problem. Happens on my Roku too.
Boostrail
Why are people accessing All 4 via Youview when it is simpler just to use the installed app directly which does not have this problem? (XH9505)
vinn
There is no installed app on Sony televisions apart from through the Youview app (and this only since 22nd December, previously no apps at all for mainstream UK channels). Believe me I’ve looked. I have a 2021 TV that used Google TV. I’m guessing it was different in the past and you have an older TV.
Boostrail
My TV as said is a 2020/21 season model XH9505 purchased in April 2021. All mainstream catch up apps are under Sony Select in the Home screen and work fine.
vinn
Ah okay I hadn’t realised that there were further apps ‘hidden’ away. Just found them. Great. However still have the audio description problem on All 4??
Boostrail
I cannot see that an app that is staring you in the face when you press the home button on the remote can be described as hidden? However being the native app on the TV it may be worth exploring the settings again to see if you can turn AD off.
vinn
Okay well we can’t all be as clever as you. It doesn’t ‘stare you in the face’. It is one of many apps on the Home Screen. Thanks for the helpful advice anyway.
Stay Puft
The Sony A8 only allows you to access All4 and My5 through YouView - the BBC iPlayer and ITV Hub are fine, but not the other two.
