ALiS 1024x512 - is it 16:9?
Discussion in 'Plasma TVs' started by Dan L, May 26, 2005.
  1. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    If I run my PC outputting 1024x512 (ALiS native res), is the picture true 16:9?
  2. johndon
    johndon
    Feb 3, 2002
    1,924
    48
    +88
    1024*576 would be true 16:9 (assuming square pixels). 1024*512 would, effectively be 16:8.
    John
  3. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    So the real question then - are ALiS pixels square?
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    No they are not, nor are there 512 vertically, there are 512 drivers, 1024 pixels. They are distinctly rectangular. It is impossible to address alis pixels natively, I've even had a go today. It's not going to happen. XGA works well, and if you don't mind some overscan, 5-7%, then 1080i is good. You will lose the taskbar though.
  5. smargi
    smargi
    May 22, 2005
    62
    so the big question is..! is alis tech is a good one when compering to other tech...?
  6. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    Trust MAW to confuse it all :confused: :rotfl:
  7. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    Oh and as I've said before, 1080i looks utterly gash through my PC - I even tried large fonts and it still looks gash :D
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    1024x768?
  9. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    1024x768 looks nice, but it won't work through the DVI port if the TV is set to DVI-STB :)
  10. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    Oh and I have a feeling that the aspect looks wrong too.
  11. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
