Alignment problem
Discussion in 'Projectors, Screens & Video Processors' started by bogfish, Apr 9, 2005.
  1. bogfish
    bogfish
    Hi all
    Wonder if any of you can help me, I am trying to setup a Sony D50Q, I can get the tubes converged fine. But an hour into the projector being on they shift very slightly out of alignment. I then tweak them to look good again but an hour later off it goes again. (They only shift a few mm)
    Anyone got any ideas on what’s wrong?
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Sounds like thermal drift as the lenses and chassis warms up. You need to re-do the mechanical lens alignment again.
    To avoid having to reconverge from scratch set up a new memory bank and use that instead of the existing banks. Warm the pj thoroughly (white test pattern or daytime TV) and then reset the deflection and convergence settings.
    Put up a basic cross hairs test pattern and then loosen the locking screws for the Red & Blue tubes. Target the red lens so that R&G overlap in a dinner plate sized patch just at the centre of the cross hairs pattern. Tighten the screws and then repeat for blue.The centre of the crosshairs pattern should now be white. You may also want to take a look at focus whilst you have the cover open.
    All that's left is to switch across to your existing memory banks and tweak deflection and convergence.
    Regards
  3. bogfish
    bogfish
    Ill give that a try, many thanks!
    James
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Also double check that all bolts holding the lens toe in are secure. (two at top two at bottom)
