Alien Quadrilogy R1 or R2?...
Discussion in 'Movie Forum' started by andy76, Dec 7, 2003.
  1. andy76
    andy76
    Is there any difference between the content of the R1 and R2 versions of this set?
    Edited films, more/less extras etc?
    Andrew
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,770
    Bristol
    +6,374
    Been a few threads about this before mate, below are the differences...
    "Region 1 allows you to listen to the audio commentary with either version of the film, but on the Region 2, the tracks are available only on: "Director´s Cut" of "Alien", "Special Edition" of "Aliens", "Theatrical Release" of "Alien 3", and "Theatrical Release" of "Alien: Resurrection". Further more, on the Region 1 discs, you can view an optional "deleted footage" marker, and you´re also able to view the "deleted footage" from the theatrical cut's "Supplements menu". Both of these options are missing from the Region 2 discs. R2 is also missing the "script to screen comparisons". Both cover and menu designs differ slightly between the Region 1 and 2 discs."
    As you can see, the differences are nothing major so guess it is upto you, im getting the Region 2 release just because it was only £39.99 and I should have it either tomorrow or tuesday.
