Alien Quadrilogy-open with care
Discussion in 'Movie Forum' started by soulbrother, Dec 1, 2003.
  1. soulbrother
    soulbrother
    I received my alien quad R1 today from cdwow,on opening and removing the cellophane wrapper on the back of the box there is an info insert which is glued to the box.Being as carefull as i could tried to remove it but it has pulled away some of the picture print .Why do they do that,i mean why not leave it loose,mine must have had more stickier glue on it ,im gutted.So anyone who has the R1 quad beware when removing the info insert.
  2. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    same with me gutted
  3. FoxyMulder
    FoxyMulder
    I almost tore mine but i glued the label back on.
  4. purplefoot
    purplefoot
    Dec 15, 2002
    33
    11
    Got the insert off without tearing the box, then managed to remove the glue with lemon oil (which is basically lighter fluid and lemon juice.)
    More worrying, there was a blob of the stuff under the disk 3 tray, whch left a mark on the disk itself. Fortunately, got it off the disk with the same procedure (after a trial run on an old disk first, of course!)
    I was lucky in the end, but not a happy bunny for a few hours there....
    PurpleFoot.
