Ali 1394 Firewire card and JVC DV357 camcorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by michaelm, Feb 11, 2002.
  1. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    +3
    I bought one of these cards from Dabs and it has installed okay using Windows own OHPC drivers on my P3 800mhz 512Mb Ram Win98SE system. But when I connect my camcorder to the card and run Ulead Media Studio Pro, it cannot detect a device.
    Am I doing something wrong or does it just sound like a dodgy card or cable?
  2. laurel
    laurel
    It's unlikely you have a dodgy cable.
    I remember, there was a problem with 98se that gave the problem you describe. This needed an update from the windowsupdate site.
    Try going to
    Windows Update
    and hit the "Product Updates" link.
    This will give you a list of possible updates for your machine. Look out for something like "1394 storage supplement".
    Let me know if this doesn't work. I can dig out the link from somewhere.
    There was also an issue if you originally updated from Windows 95. Different fix. Let me know if this is what happened.
    Laurel
    PS. Also make sure you have 98se, as the plain Win 98 does not correctly support firewire.
  3. YJ
    YJ
    Jul 13, 2000
    54
    9
    Middlesex
    I also had a bit of trouble but found out it was down to the PCI slot being shared by another device and to ACPI making all the devices use IRQ 9.
    The link below was very helpful in highlighting what you need to do to make your OHCI Firewire card work.
    http://www.ramelectronics.net/html/ieee-1394_support.html
  4. nkasic
    nkasic
    I have JVC GR-DVP9 and worked fine on my XP laptop, but I couldn't make it work on Win2k. It wasn't detected.
    I spent 2 weeks and discovered just last night that it works when I unplugged my network cable. I tried everything before, re-shuffled cards, re-installed software several times etc.
    At the end I replaced network card and now it works fine.
    Strange.
    Network card and connection was working fine otherwise.
    Nik
  5. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    +3
    I'd forgotten about this post until now :blush:
    Anyway, here's an update.
    Dabs refunded the card and told me not to return it. I upgraded to XP and the card works fine :D
  6. lampshuk
    lampshuk
    I have the same DV camera as you, Michaelm - no problems with Firewire and XP - however - I am curious to know if you have succeeded in getting the DV-IN facility to work. I want to transfer finished movies to DV tape for archiving and the inbound link to the camera doesn't work propoerly. Have you tried this yet?
  7. lampshuk
    lampshuk
  8. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    +3
    Yeah, I used Ulead Media Studio Pro and sent the finished product back to the camcorder and it plays no problem. Since then I have invested in a DVD-RW and now put all my home movies on to dvd.
  9. JayX
    JayX
    Dec 10, 2002
    341
    29
    c-town
    +28
    lampshuk : i have a 357 too, and the DV IN works fine. i use Vegas4.0 for my editing ( www.sonicfoundry.com more comparable to premier for pricing/quality than anything like ulead (which i cannot stand)) and i've rendered videos to DV and sent to the tape. make sure u set dv in on the camera first (change to PLAY and press record to arm it, then record again to trigger)
