Alfa Blaupunkt CD - Steering Wheel Controls
Discussion in 'Portable Disc & Media Players & Recorders' started by ToshTV, Aug 29, 2005.
  1. ToshTV
    ToshTV
    Hi guys
    Last night the steering wheel controls in my Alfa 147 GTA went a bit funny.
    I have the standard Blaupunkt CD / Bose set up.
    In particular it is the controls on the left hand side. The mute button now does not mute, the volume down button does not work and the volume up button mutes it.
    It is a little bit annoying and I was wondering if anyone knew of a fix i.e. reset radio / new fuse etc.
    Typical that it would happen when I was taking a friend out for a run and he was saying "in the past Alfas had a reputation for being unreliable" blah blah blah :)
    Cheers!
  2. Gazpilot
    Gazpilot
    Aug 24, 2004
    82
    Try alfaowner.com or even the forum on alfa156.net (same radio and they have a 147 thread).
  3. ToshTV
    ToshTV
    Magic - thanks for that.
