Alesis power amp
Discussion in 'Home Cinema Building DIY' started by Howard0000, Dec 12, 2004.
  1. Howard0000
    Howard0000
    Jan 11, 2003
    1,066
    48
    Surrey
    +88
    I'm sure many of you are aware of my seemingly ongoing sub project, here:
    http://www.avforums.com/forums/showthread.php?t=93244
    Well the only piece of the jigsaw left really is to find some decent amplification.
    The Technics amp I'm using to power it is becoming a bit flakey.
    I've found what seems to be the perfect item to run it.. Everything seems to be suitable. It's an Alesis RA150 Power Amp, shown here:
    http://www.alesis.com/products/ra150/index.html
    Basically I'd like to know if that would be as suitable as I hope... I searched and someone else is using the higher powered version, so it can't be too bad.
    What does everyone think?
