aldi freeview boxes
Discussion in 'Freeview & YouView' started by shacky, Aug 6, 2005.
  1. shacky
    shacky
    Jun 12, 2005
    381
  2. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +309
    That's confusing. It says it's a "Free To View" box, implying that you'll need a viewing card.
  3. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    For £33 I will give it a go if my local Aldi has them.
    I seem to remember there being an Aldi Tevion DVD recorder some time ago, you may be able to find reviews for that which might give you a picture.
  4. TrevP
    TrevP
    Nowt confusing about it at all. If you select the item, quite clearly is Freeview box.
  5. jenic
    jenic
    Dec 10, 2004
    2,871
    83
    +179
  6. ctcrm
    ctcrm
    May 6, 2003
    134
    think ill get my mum one of those.
  7. bluefoxtim
    bluefoxtim
    Jul 28, 2005
    43
    +3
    I have that box and even in a very poor signal area (with no coverage according to freeview site) and a VERY old arial, my signal is just fine, signal strength 58% quality 98% :) on most channels
    I really recommend this box, and for £30 you cant go wrong
  8. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    is the aldi one top up tv compatible?
    also, does it output in RGB?
