Aldi 27" LCD TV NTSC problems????
Discussion in 'LCD & LED LCD TVs Forum' started by GPMCDERM, Jan 11, 2005.
Tags:
  1. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Has anyone tried out NTSC with this monitor??? No probs in PAL
    I picked up one here in Ireland and have to say I was very happy
    but even though it WILL display NTSC the frame rate is wrong
    this is in prog scan (Philips 963 and 630) and non-prog (Sony 725)
    the same problem is also seen when using PAL60 with either the
    Xbox or the Gamecube...have I a dodgy set or has anyone else seen this.
    manual is fairly bland states pal/secam(is there another model with NTSC?)
    assumed this meant the tuner which I'm not using just got it for consoles/dvd for upstairs but a real pity if it won't do ntsc as the pictures are
    great but the jerky pic is a pain....half my DVDs are R1 and the PAL60 mode
    is useful, this even shows up when using VGA on a Dreamcast(yeah I know)
    picks its up as 480P and again the framerate is off...
    Cheers...
