Aldi 160gb DVD recorder and $ky +
Discussion in 'Digital TV & Video Players & Recorders' started by gazjen, Sep 1, 2005.
Tags:
  1. gazjen
    gazjen
    Hi All
    I've been looking at this Aldi HD dvd recorder I want to record off sky to DVD would this unit allow me to do it automatically? I've read somewhere that you can press something on sky+ to dump to VCR can this be done on the aldi dvd recorder?
    Any help greatly received
    Gazz
  2. marty2005
    marty2005
    Jul 22, 2005
    3,691
    Great Yarmouth
    +155
    I have the same tevion 160GB - read earlier posts.
    On the back it has scart, svhs and composite input.
    So it should work. Do you mean getting the $ky+ box to control the dvd recorder ? - so when you press play on the $ky+ it will start the dvd into recording.
    That can't be done - it can on the front DV input though using dig-camcorders.
