alba dvdp500? anyone know a hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by dalebosworth, Dec 2, 2004.
  1. dalebosworth
    dalebosworth
    helloooooo,
    just wondering if anyone knew how to make the alba portable dvd player p500 multi region? i've been looking for ages and i can't find one anywhere? any help would be much appreciated.
  2. Huberto
    Huberto
    I Have likewise trawled the internet for ages in order to find said hack. Either one does not exist (unlikely) or it hasn't been discovered yet (hard to beleive). If I have any joy I'll let you know.
  3. yelselseivad
    yelselseivad
    I have code for Coby TF-DVD5010 which I think is same e-mail me @[email protected] and I'll send it to you.
  4. Huberto
    Huberto
    This Alba player looks identical to a Coby and a Yamada model. There is a hack for these but I can't get it to work on my Alba. Had any better luck?
  5. Huberto
    Huberto
    What a donkey! When I put back the battery from the remote (that my daughter had sneaked out) it worked perfectly....Durrr!
    Thanks a lot Yelsel... or is that Lesley?
  6. Kermyt
    Kermyt
    2120090 bingo there is your code, turn on, open disc tray, enter code....game on......region full
