Quantcast
alba dvd 55
C
Cervinus
Just bought Alba DVD 55
Thought it had a hack to multiregion use but the alba hacks so far do not work!
H O W E V E R - If you load your (region 1) dvd and press "enter" or "close" and wait while it flashes "loading" if you keep pressing "1" - it will say "wrong region" but play the dvd.
Disadvantages -
1) All the other function buttons on the remote are disabled apart from "setup" but that is no great help!
2) It displays "wrong region" in top left corner throughout
3) It displays sub-titles which you can't turn off
Apart from that everything else seems to be OK!
If anyone comes up with anything better - especially region free - I'd like to hear from you please!
Cervinus
