Alba DVD 103
Zola_Blue
I am planning to import Region 1 DVDs.
Does anyone know if this player will play them automatically or does it need to be hacked? If it needs to be hacked can someone please advise as to how this can be done.
tbibic
From what I remeber of working at Argos, Bush and ALBA are usually the same - try this hack for the Bush DVD-102
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the buttons 2, 0, 0 and 1 on your remote control
3. Press the Enter button on your remote control
4. You will now enter the hidden setup page, and can change the player to any Region or set it to Region Free by entering 13 as the country code.
5. Press the Open/Close button on your remote control to close the drive tray
Courtesy of http://www.dvd.reviewer.co.uk/info/multiregion/hackable.asp?Page=2
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
