Alarm and CCTV
Discussion in 'Smart Home, Climate Control & Security Forum' started by Smashie1, Feb 7, 2014.
  1. Smashie1
    Smashie1
    Feb 7, 2014
    I will shortly be moving to my new (1930's) house and it has not currently got an alarm. My current house has one and I would like to get one professionally installed in my new place.
    I was looking at the Texecom stuff as I can go for a mix of Wireless (Ricochet) and Wired. What do you think of this system? Is it good or should I be looking at something else? The wireless part of it from reading seems to be very good. I would not go for monitored, but would require the alarm to be able to notify me with which sensor was tripped (probably don't need this but I like bells and whistles).
    In addition, this place does not have a garage, just a huge driveway and a shed. I therefore want to install CCTV cameras. I am thinking of 2 at the front which will cover my ground floor office and the driveway (with occasional caravan) and 2 at the back to cover the shed and the entrances. As I have no garage, all the stuff such as bikes, roofbox, tools etc will be in the shed
    Until I move in I do not know exactly on the setup that I would go for on the cameras, but I was thinking of 1 providing an overview of the area and 1 giving a narrower coverage so as to be able to identify people. At the end of the day I do not need the detail of them trying to break in if I can get that detail when they approach. I would be looking at retaining 2-3 weeks of data and would like remote access via Android/iPad (2Tb?).
    I am hoping that approx £1k will be enough for the hardware (CCTV). There will also be PIR lighting at both front and back. What would you guys suggest for this? So far I have seen stuff on on cctv42.co.uk and cctvdirect.co.uk, but not sure if either would suit my needs. I do not want to go for a PC/Laptop based solution.
    Thanks for reading. Looking forward to your comments.
    Dave
  2. z3r0c00l
    z3r0c00l
    Jan 5, 2014
    297
    Somerset, UK
    +52
    I've had a Pyronix Enforcer alarm system fitted now for a few years and been immensely impressed with it! It can be configured with remote monitoring if needed although when it comes to bells and whistles I tend to use the RFID tags to set/unset. also have a tag configured to only set part of the system, which cannot be used to unset....handy for external areas!
  3. Dondada69
    Dondada69
    Feb 16, 2014
    London
    Hey, Texecom is very good but I'd say also have a look at the Visonic Powermax Complete before you make your decision. It is very versatile and expandable.
  4. Ianandanne
    Ianandanne
    Jan 23, 2014
    80
    +5
    I love Visonic, lots of great features.
