AKG 450 Or AKG 451
Discussion in 'Headphones, Earphones & Portable Music' started by camcroft, Mar 12, 2013.
  1. camcroft
    camcroft
    Jan 11, 2012
    +5
    Which one do you think is the best ?
  2. Soundmangt4
    Soundmangt4
    Oct 14, 2012
    1,832
    116
    Bromsgrove, Worcestershire
    +970
    Same headphones as far as I can tell, only the 451's have the in-line mic and controls, where as the 450's it is an optional extra.
  3. camcroft
    camcroft
    Jan 11, 2012
    +5
    To answer my own question.The 451`s got some this morning and they are a lot better sounding than the 450`s.
  4. Tatty
    Tatty
    Sep 26, 2006
    3
    I'm genuinely interested - how are they a 'lot better sounding' when they are exactly the same except for the inline mic on the lead?
  5. camcroft
    camcroft
    Jan 11, 2012
    +5
    They are more open sounding than the 450`s and they look similar but they are not.They are a different colour than the 450`s
  6. Tatty
    Tatty
    Sep 26, 2006
    3
    Yes -I knew the colours are different but I was referring to the Technical Specs. From the AKG website it shows that they are exactly the same. I have heard someone else say they they thought they sounded different and I was wondering how that could be possible. Burn time on the demo model could be a possibility? Hence my interest.
    http://uk.akg.com/tl_files/catalog/...ini/Specification Sheet - K 450 (English).pdf
    http://uk.akg.com/tl_files/catalog//AKG/AKG/Spec sheet/Mini/Specification Sheet - K451 (English).pdf
  7. camcroft
    camcroft
    Jan 11, 2012
    +5
    Hi.The specs must be right then.I should have gone to specsavers
