Akai DV-P2100 multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,545
    7
    167
    Birmingham, UK
    +10,364
    * Open the disc tray
    * Press 3838
    * Using the secret menu select 1 for region 1, 2 for region 2 etc. or 9 for multi-region
    * This menu also allows macrovision disabling
    * Press I to exit the menu
  2. Dolce
    Dolce
    I was hoping someone could help me find a hack for my DVD player. I just moved to italy, picked up a DVD player (think it was unlocked) and have too many North Americna DVDs that it would kill me to give them away.
    Can anyone help? If so you will have have a new "best friend"
    Akai DV- PX 7580
  3. carl_xxi
    carl_xxi
    Open tray
    Press: 1 0 3 0 0 on the remote, region 0 will be displayed at the screen, the player is now multiregion, if you want it back to region 2 you just, do the same thing but put in 1 0 3 0 2 instead.
    Works fine on my Akai dv-px7580k
    Micael:thumbsup:
