AJ Electronics/Sony TRV33
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by craig1912, Oct 21, 2003.
  1. craig1912
    craig1912
    Dec 16, 2002
    1,559
    +356
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,119
    Rainham Essex
    +2,388
    I've never used AJ Electronics so can't help there.
    Accessories that you will need are at least 1 extra battery as the supllied one will not last long.
    You will also need plenty of DV tapes. These only cost £3-£4 so I tend to only use them once. Also you should always stick to the same make of DV tapes.
    If filming inside you might want to get a light. DV camcorders are not the best at recording in low light levels.
    All the above is just for the camcorder. If you want to start editing the video on your PC then there will be plenty more to add to the list.
    Mark.
  3. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    I got my TRV33 a few weeks ago from AJ Electronics and it came within a couple of days of ordering, so I'd have no problems in recommending you buy from them (especially as the price is so good at the moment).
  4. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    is it still £549?
  5. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    No it's better than that - only £532 (why didn't you just click the link?)
