T
Trout
Ok I bought an Aiwa XD-DV480 about 3 months ago from Richer Sounds.
"Stop giggling at the back there"
Seriously though I did want the Aiwa
They did the Multi Region upgrade in shop and it works great playing region 1 and the rest.
The problem is that not being completely up with the buffs when it comes to the know how of home entertainment I was unaware of the dreaded "Regional Coding Enhancement".
Now I want to purchase the Region 1 Spiderman and guess what, as most you are probabbly aware it's got RCE.
My question's are these,
1: does anyone else out there own the same model Aiwa with multi region set and knows whether it will play RCE.
2: does anyone know where I might find out without having to spend money on a RCE DVD just to see if it will work or not.
Hope someone can help,
