Aiwa turntable LX70 and mini hifi NSX-AV95
renots
:lease:Can anyone help. After a move 18 months ago I have lost manuals.I am trying to get my system back up and and running.I have connected all speakers but am struggling to conect up turntable. The red and white cables are not a problem but there is a black wire with a plug on it and a second wire which I recall detaching from a screw . BUT which one and where. Regards Graham
BlueWizard
If you amp has a true PHONO input, then the screw is probably very near that PHONO input. At any rate, that screw just ground the wire to the chassis, so any frame screw will do.
Steve/bluewizard
renots
Steve/bluewizard
Hi Steve
I am definitely not hifi literate) as you can see) so many thanks for your advice.
I will connect the wire to a screw on the hifi chassis.
With regard to the black wire with plug. I believe this was some type of syncronising mechanism however i do not remember it being connected. Is this the case. Or should it be connected to the 'phono input'.
Regards Graham
