aiwa potable tv with video plus
Discussion in 'TVs' started by chapm, Apr 14, 2005.
  1. chapm
    chapm
    having problems with tunning the set it will not hold on any station using manuel or auto search, can anything be done
  2. JayCee
    JayCee
    Jan 20, 2004
    20,225
    Lanarkshire
    +1,937
    You need to supply the complete model no! :lesson:
    When you say it will not hold the tuning after finding a station are you storing it correctly?
  3. chapm
    chapm
    when doing channel search the bars are moving but not stopping on any channel the model is vx-g145k
  4. JayCee
    JayCee
    Jan 20, 2004
    20,225
    Lanarkshire
    +1,937
    If you have a good strong signal from the aerial and during a manual tuning search it does not stop when a signal is found I'm afraid you have a fault and require an engineer. :(
