aiwa ht dv90 help
Discussion in 'Blu-ray & DVD Players & Recorders' started by godboy, Jul 22, 2004.
  1. godboy
    godboy
    i have a aiwa ht-dv90 i have had this for about a year,with no trouble until today,when i try to turn it on,the word protect comes up on the screen and it then turns itself off.....can anyone help....ta
  2. robinnumberone
    robinnumberone
    hi there,
    ht-db90 has got loads of problems. and most of it is the bugs in the way the program works in the system. anyway if you have any trouble and you don't know what went wrong. press the stop button and hold it for a few seconds till the system power goes off and comes back. this resets the settings to its default. try this. hope it works.
    good luck
