Aiwa DV90 multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,811
    2
    167
    Birmingham, UK
    +9,530
    1. Press DVD/CD
    2. Open the disc tray
    3. Press C2580C
    4. The display wil read TESTMODE and show the currently selected region
    5. Press the Up arrow until the display reads 14 02 (02 indicating region 2). This may be different if your player is not set to region 2.
    6. Press 14 and then 1 to select region 1, 2 for region 2 etc and 0 for multi-region
    7. Press Enter, Return (TESTMODE is displayed again) and C
    8. You should see the player display EEP CLR EEP ERR
    9. Put your DVD in the tray and press Return
  2. bcox999
    bcox999
    Nov 22, 2005
    7
    3
    Leigh On sea
    i previously entered this hack and shortly afterwards it started reading the discs badly. It jumps as if its having trouble reading the imprinted dvd and then says no disc !!!
    so i reset to UK region and then re-entered to multi-region.
    it now reads nothing, only cd's.
    is there some form of master reset button, or how can this be solved.
    also have you / anyone else experienced this.
    many thanks
    Barry
    :lease:
