Aiwa Av320
Discussion in 'Hi-Fi Stereo Systems & Separates' started by niccam, Jul 20, 2005.
  1. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Hi can someone please explain why my AIWA would just for no reason make loud popping sounds when switched off its on at the plug but off at the switch . Its a Pro-logic system but as said before its off when these loud popping noises come through the speakers. Please can someone explain?
    Thank you
  2. jon_mendel
    jon_mendel
    Jan 15, 2005
    852
    +9
    If you mean it's plugged in, but you're pushing the on/off button on the amp, this isn't uncommon (apparently it can be something to do with the capacitors discharging). How loud is the popping?
    Try turning the volume knob down to zero b4 turning it off - see if that helps...
  3. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Thanks jon It is plugged in and turned on but turned off at the power standby button on the system and the popping noise can be really loud at times. I will try turning the volume down b4 turning off. Thanks
  4. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    well tried you suggestion but it did not work and to cap things the system has no volume now ( nothing to do with you jon ) seems as my system has died as the some of the button don't respond at all . The sad thing is this system had very little use and and is sitting like new it is about 5 years old
    Is it worth getting fixed?
  5. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    UPDATE : the system made aloud bang and the system is now back to normal obviously there is a fault in the sound and this is making the loud popping sounds as well as no volume at different times will need to get it checked out.
  6. jon_mendel
    jon_mendel
    Jan 15, 2005
    852
    +9
    Yeah, clearly something ain't working right. Depending how loud the bangs are, you might want to hold off on using it - there is an off-chance a bang could blow a speaker if it's v loud :(
    As to whether it's worth repairing, guess it depends on how much you like the system and how much it's worth (and if you're wanting to upgrade...) If you're happy with what you've got, it *sounds* like it could just be a loose connection or socket somewhere - see if you can get a local hifi/electrical store to give you a reasonable quote on fixing it.
    Jon
