Aiwa AV-D58 - recommend me some speakers!
Discussion in 'AV Receivers & Amplifiers' started by minimal_fuss, Jun 24, 2005.
  1. minimal_fuss
    minimal_fuss
    Jun 24, 2005
    222
    Norwich
    Hi i recently picked up some cheap AV bits:
    (Already have MD deck/DVD deck/Media pc)
    -Aiwa AV-D58 for £30inc.
    -Kenwood LS-54 for £20inc
    -Technics sb4000 for FREE.
    -The aiwa av unit is one of the best budget units from what i've heard, 5.1 and 80watt per channel btw.
    -The Technics speakers work fine and seem good mid-range, i belive they are around 20 years old though and i've never found any information on them other than there wattage. I'll probably use them as my rear surround speakers.
    -I should receive the Kenwoods this wknd, have never heard of them but the specs looks fair enough and for that price I can sell them on if they arnt very good. (8ohm 80watt 45hz-25khz).
    Would one work ok as my center speaker????
    -I've got about £100 budget (not alot i know) With which i'd like to get a pair of front speakers, floorstanding or floormount, but basically the best i can get for the money for this unit.
    -(im not worried about a sub as im at uni and would have to have it turned off most of the time anyway)
    -Ideas?
