Aiwa 701 DVD Hack Needed
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by sanorman, May 2, 2002.
  1. sanorman
    sanorman
    Mar 26, 2002
    13
    Aiwa 701 DVD
    I just bought this good looking DVD/5.1 Speaker system from Makro and i am looking for a hack without success.
    Does anyone have one?
    Has anybody else bougt this system.
    thanks
    Steve
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,601
    7
    167
    Birmingham, UK
    +10,463
    You're doing things the wrong way round.
    You find out which players actually produce a decent picture and sound and which may have hacks and THEN you go out and purchase the kit.
    The wrong way to do it is to see a player in a shop, think 'mmm that looks ok, and I can afford it - I'll buy it'.
    Oh well maybe next time.
    With regard to the hack, I don't think there is one.
  3. RickA
    RickA
    Yes I have and I am still looking for a hack
    Rick:confused:
  4. RickA
    RickA
    The only hack found so far is as follows (but region 1 in B&W):
    "This is not a multiregionhack, however it will allow you to play copied disks.
    The bad news is that when the player is powered down you have to re do the hack.
    1. Unplug the XR_DV701 from the electrical outlet.
    2. Press the DVD/CD button while plugging the unit.
    ** Do not let go of the DVD/CD button **
    3. While holding the DVD/CD button, Hold the FastForward (>>)Button.
    4. The LCD Screen changes to show S46 M00
    5. Play your copy"
