Airport Express / Squeezebox
Discussion in 'Headphones, Earphones & Portable Music' started by scrapbook, Jan 1, 2005.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,117
    +529
    I was just wondering if there were many forum members using either of these products?
    So how are you getting on with them?
    The squeezebox looked expensive intially, but by the time you add in the cables required for airport express there probably isn't much in it.
    Soundblaster Wireless Music looks interesting, but not sure if compatible with itunes when it is released.
  2. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    I'm using an Airport express, and get on ok with it. Needing to use a laptop to control it (thru iTunes) is getting a bit of a pain, so I'm going to add a Keyspan Express Remote, then I think I'll be happy with it.
    Which cables are you thinking of ? I only had to spen about a fiver on an optical digital cable.
    Cheers, Carl.
  3. scrapbook
    scrapbook
    Jan 12, 2002
    7,117
    +529
    I was looking at the official apple leads...is it just a normal optical lead then than leads from the airport?
    Yeah i am currently considering whether that will be a pain or not. If it is may way go for the Creative set up...comes with an LCD remote that lists all your tracks on it
    Hows the signal with the airport? the problem with plugs is that they tend to be hidden away!
  4. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    The official Apple leads are overpriced. For the digital output, a 3.5mm to Toslink, like this, will do the job.
    I have no problem with the signal - mine's stuck in the AV rack, on the end of an 8-way socket. So it's under the plasma, and surrounded by lots of electronic gubbins, but no problems with drop-out or popping or clicking. Pretty good stuff.
    What's the Creative set-up ? An LCD remote with track lists sounds good ... does it work with iTunes too ?
    Cheers, Carl.
  5. DVDNUT
    DVDNUT
    Nov 10, 2002
    147
    Kent
    +5
    Creative set-up does not work with iTunes.
    Squeezebox is good for an all in one solution.
    I use Airport Express and find it very good.
    Due to moving, I now have one of these up for sale (I now have one less room, so only need two Airport Ex).
  6. pob
    pob
    Mar 28, 2002
    1,416
    Sheffield, UK
    +83
    I have a squeezebox and love it. Easy to setup, easy to use. Simply install a small application on your PC and then select your music on the squeezebox remote.
    Highly recommended.
    Phil
  7. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,236
    +63
