Question Airplay Sky Q on iOS to Sonos?
Tellymonsta
Hi folks,
I have a new iPad and using the Sky Q app to stream video. Is it possible to output audio to Sonos rather than use the iPad speakers?
Thanks!
Ian
Cebolla
You should be able to, via AirPlay - as far as I'm aware Sky's AirPlay block on its apps is for video, not audio.
This assumes your Sonos setup has at least one Sonos device that supports AirPlay 2, ie, Sonos One, the second generation Play:5, Playbase and Beam. However, if you Sonos setup consists entirely of other Sonos devices, then no.
Tellymonsta
Thanks. I don’t see an “Airplay button” in the Sky Q iOS App - I assume this is required to send audio via Airplay, therefore I don’t think this is possible.
I’m comparing to YouTube, for example, where there is an AirPlay button and I can send audio to AirPlay / Sonos.
Cebolla
It's likely that Sky have deliberately not provided an AirPlay button on its Sky Q iOS app to highlight that they've blocked video AirPlay.
You should still be able to select the AirPlay 2 supporting Sonos device as an AirPlay speaker in the normal alternative way from the iPad's Control Center.
