Air Tunes Express any good?
Discussion in 'Headphones, Earphones & Portable Music' started by schillaci0, Feb 26, 2005.
  1. schillaci0
    schillaci0
    Jan 18, 2005
    670
    Starting to get where I want to be
    +14
    Has anyone have any experiance of the air tunes express for streaming music and net connection to ethernet port for data streaming.
  2. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Yes on the air tunes bit - it works just fine. I used to get the odd drop-out now and then, usually when the local moped boys came zinging up the road, but that was rare enogh that it wasn't a problem.
    Yes, kinda, on the ethernet port bit. I was using it as a wireless bridge for my xbox. Again, works just fine.
    Cheers, Carl.
  3. schillaci0
    schillaci0
    Jan 18, 2005
    670
    +14
    I presume that you have to have itunes running on your pc with the relevant playlist etc first, is that correct.
  4. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    That's it. There's a good explanation of it all here
