Air spray for PS3 cleaning
Discussion in 'Playstation Forums' started by bajere, Jun 16, 2009.
  1. bajere
    bajere
    Oct 16, 2007
    1,361
    Bristol
    +40
    Hi all,
    My Playstation (60gb-launch) is getting very hot and noisy, i have heard that blowing compressed air through the system will help this...
    is this can OK to use: Air Duster > Maplin or shall i get a different/more powerful can???
    thanks in advance
    Baj
  2. Darth_terra
    Darth_terra
    Jan 13, 2006
    5,094
    UK
    +946
    That's perfectly fine, i use that type for my PC as well as PS3 and it does the trick well enough. :)
  3. clc.sheff
    clc.sheff
    May 28, 2008
    3,560
    Steel City
    +1,873
    So much for air being free :D
  4. Darth_terra
    Darth_terra
    Jan 13, 2006
    5,094
    UK
    +946
    :rotfl: well i wouldn't want that air blasted into my lungs.. pop
  5. bajere
    bajere
    Oct 16, 2007
    1,361
    Bristol
    +40
    :rotfl:
    very true.
    thanks for the input lads, ill pick sum up tonight. might even get one of those fans to attach to the back of the playstation
  6. Ed the Penguin
    Ed the Penguin
    Jan 14, 2008
    1,195
    Rugby, Warwickshire
    +142
    Just don't hold the can upside down or else water may spray out! It's best to keep the PS3 at the same level as the nozzle to ensure the can is kept upright. :smashin:
    Watch out with the fans too as I've heard most are as much use as a chocolate fireguard.
  7. bajere
    bajere
    Oct 16, 2007
    1,361
    Bristol
    +40
    thanks for telling me that...so i should turn it off when i do it then, just in case of water?
  8. Ed the Penguin
    Ed the Penguin
    Jan 14, 2008
    1,195
    Rugby, Warwickshire
    +142
    It's always best to turn electrical equipment off when cleaning.
    Switch the PS3 off, don't spray too long, keep the can upright and all should be fine!
  9. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,229
    Born in Bristol but now in Newport, (for my sins)
    +752
    Its not water.. Its simply a chemical which is liquified under pressure. It could cause damage to electronics if they are powered up.. But as long as its switched off, the liquid won't do any harm as it will simply 'boil' off!
    Jon
  10. ham_rye
    ham_rye
    Apr 20, 2009
    174
    +9
    Air's free, 1,1,1,2-Tetrafluoroethane isn't :lesson: :cool:
  11. clc.sheff
    clc.sheff
    May 28, 2008
    3,560
    Steel City
    +1,873
    Not if it's a pump action one :)
  12. Ed the Penguin
    Ed the Penguin
    Jan 14, 2008
    1,195
    Rugby, Warwickshire
    +142
    Thanks for the correction, you are quite right!
  13. bajere
    bajere
    Oct 16, 2007
    1,361
    Bristol
    +40
    well i got the can, and gave the Playstation a good dust off... LOADS of crap came out the back of it!!! but it still runs hot, and the fans make a lot of noise...
    any thing else i can try??
    cheers
    baj
  14. fawaz
    fawaz
    Jan 16, 2009
    54
    +7
    Vacuum out the dust. I tried compressed air, didn't do much. Got a vacuum and that worked alot better. Apparently you should use a weak vaccumm, I just used a dyson and held it a bit away from my PS3.
  15. Leights1978
    Leights1978
    Nov 25, 2007
    280
    +16
    Bajere
    There is a function built into the PS3 which cleans itself out by increasing the fan speed for a few seconds, this may help but it not recommended by Sony for regular use.....the only roblem with my advice....I cannot remember how to do it!!!!
    Somethig like complete power off, hold the standby button down as you turn mains power on.... I am sure someone on here will know!!
  16. bajere
    bajere
    Oct 16, 2007
    1,361
    Bristol
    +40
    i did the vacuum 1st, but nothing happend, so i tried the air... but still no big difference. i might try the vacuum again now iv used the air, the air could of unblocked a few things and the vacuum will suck it out. (perhaps.lol)
  17. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    Bear in mind this function isn't present on 60Gb models.
    Also, as far as I am aware, Sony have never made any comments about this feature.
  18. bajere
    bajere
    Oct 16, 2007
    1,361
    Bristol
    +40
    yea i have herd of this, but i have a launch console.
    it never used to be that noisy, maybe my room is getting hotter or something
  19. Darth_terra
    Darth_terra
    Jan 13, 2006
    5,094
    UK
    +946
    Something you can try is standing it up vertically if your not doing so already, and if your able to do so, this seems to help with the air flow and the fan doesn't seem to ramp up that much.
  20. bajere
    bajere
    Oct 16, 2007
    1,361
    Bristol
    +40
    ah, cant do that as the space it is in, would get in the way of tv... im guessing the exhaust vents have a problem with pumping the hot air into the path of the air inlets when the console is led down.
  21. Ed the Penguin
    Ed the Penguin
    Jan 14, 2008
    1,195
    Rugby, Warwickshire
    +142
  22. bajere
    bajere
    Oct 16, 2007
    1,361
    Bristol
    +40
    yea i looked at that yesterday... im not to sure about that. if you block a vent, then the air will just get out another way. and that could mean back over the components it was trying to cool...
  23. GMC79
    GMC79
    Apr 1, 2006
    10,631
    Glasgow
    +3,172
    Im lucky i got big proper compressor in garage for cleaning PS3 and 360 dust out. These cans may not have enough pressure to work well, mayb ok but nothing like a major blast of proper compressed air to release clouds of dust. :rotfl:
    I try and do it once a month if i can be bothered, Must do something as never had my PS3 crash and never had a crash on my 360 since it was fixed 2 years ago and i started cleaning stuff properly after that. :smashin:
    If anyone has access to one i reccomend it. Carefully tho.
  24. Ed the Penguin
    Ed the Penguin
    Jan 14, 2008
    1,195
    Rugby, Warwickshire
    +142
    My mate works for RAC and he's bringing his compressor round to clean mine out.. Never done it this way before though! Is there a safe distance to recommend as I don't want to damage the fan bearings or anything! :eek:
  25. GMC79
    GMC79
    Apr 1, 2006
    10,631
    Glasgow
    +3,172
    No really sure all seemd ok for me, Just give it a good spray in the back and sides moving steadily around just be sensible with power if it's a strong one, ive had no problems and if bad u will see stuff come out easily. And if it never been done im sure u will see a ton come out. gently anywhere else there's gaps i do aswell (not dvd drive slot)
    Had litterally clouds come out my 360 at first when i done it, Handy thing to have it is, great for cleaning a pc too.
  26. Ed the Penguin
    Ed the Penguin
    Jan 14, 2008
    1,195
    Rugby, Warwickshire
    +142
    Well he stopped by in the van yesterday. I gave it a good blasting (plenty of dust!), hoovered it and then did the Power/eject fan test :)eek: I know, naughty!). Runs very quiet after playing some Motorstorm and using Vidzone. Next test is playing DVD's.. The upscaling always kicks the fan into action!!
